Starting problems
Starting problems
Whats going on guys? I'm having starter problems with my civic . This morning i put the key in and turned it and nothing happened. All power seems to be fine fuel pump was heard and everything but it doesnt seem to crank , make a noise , or nothing . If someone can please help me out i would really appreciate it . Thanks in advance.
Re: Starting problems
check the ground on the starter. also make sure the positive wire is connected properly to the starter. if it is then its probablly going to have to replace the starter.
check all the obvious and then if thats okay it sounds funny but while you are trying to start it have someone else tap on the starter with like ur tire tool somethin metal and if it start replace starter but if not check ur starter relay
EGed up from the seat up
05-13-2010 11:34 PM
