STARTING HELP!!!
STARTING HELP!!!
92 eg si hb w/ d16z6
I was at a red light proceeding to take off an the car stalled.. It was runing fine the entire day, I then try to start it an it just turning an cranking not wanting to start.. Lots of juice getting cuz it cranks hard, lights radio all work fine full force.. I wait 5 minutes an try again still cranking.. A tow truck apears take me to my place.
Try to start it one more time, it cranking an cranking - then it goes pufff like a lawnmoyer backfiring.. then i smelt like fuel? as if it was flooded i figured..
Next morning , I hold down the accelerator an crank it over .. hoping to let the computer clear the flood if there was one... still cranking i taped the fuel tank
with a mallet lightly to maybe think fuel filter or something came lose.
any ideas??
today im gona test for a spark to see if it jumps from wire to ground
any ideas??
Re: STARTING HELP!!! (nichols_si)
check your TPS or MAP sensor. my car was doing that for a while but i swapped motors before i figure out what it was. run your engine check codes and see what comes up. good luck
yea i checked for fuel tank , main relay + fuel filter is all good
turns out no spark - so im getting my honda mechanic to put a new ignitor in to test it out
RobertoHdz
14
10-10-2018 01:15 PM
Integra4lyfe069
15
03-10-2009 02:51 PM
