Start but dies after start
It cranks a couple of times then starts and dies quickly after unless I hold the gas pedal in a little. It shakes when I am holding the pedal down.
I have a b16 with a str tb, I know it is an air problem but I have double checked everything and I am stuck.
Re: Start but dies after start (Jdmbsixteen)
My map sensor could not get an accurate reading from the tb so I moved a line from the cruise control as a source.
Make sure you didnt get the map and the TPS plugs backwards. Very easy to do. Would also suggest checking the IAC to see if its pluged up.
Re: (MichaelJComputer)
Update. I had a fucked up distributor with was creating a knocking/squeaking sound. I replaced the distributor with a new one and knocking/squeaking sounds goes away. I am still having problems with my idle. Like I said before I can not keep the car on unless I give it gas. Also I triple checked to make sure I was in proper firing order. Map and tps or not reversed.
1 Post
Re: (Jdmbsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmbsixteen »</TD></TR><TR><TD CLASS="quote">Also my plugs are toasted. They are all black. This is the second pair of plugs that I went through today. </TD></TR></TABLE>
Is it possible that you could post pictures of what your plugs look like, because if you can do that I may be able to assist you more from that point.
Also I used to have this problem with my cx. Does it seem to run rough?
I would check your PCV valve, that caused mine to die out at idle all the time and I replaced plugs, wires, cap, rotor, distributor and fuel filter before I found the real problem.
1 Post
Re: (2trix)
I never got a single code for the PCV. The way I figured it was that was by a very expesive process of elimination, and in the end it ended up being a $1 part. Figures.
When I pulled the PCV (which was a complete bitch by the way because I did not remove the IM) the valve was completely seized. I blew compressed air through it and it took a few minutes to break it loose.
Re: (Jdmbsixteen)
I will post pics of the plugs in the morning. I bought the distirbutor brand new. (i.e. Rotor,cap, ingniter everything brand new). Someone said that I might have jumped a tooth. Any thoughts on that would be appreciated.
Re: (Jdmbsixteen)
did the problem start happening without warning? i guess it could be a jumped tooth or two.
if you jumped a tooth on the timing belt, you can just remove the valve cover and set the motor to TDC, #1 cylinder. Check the cam gear markings and crank pulley TDC mark vs. the pointer. It takes about 2 seconds to see if you're off a tooth on the intake or exhaust cam.
Just use that part of the timing belt change procedure to check for TDC. or do a search.
Re: Start but dies after start (5thgenjon)
Update: I got the car running and it turns out the reason my idle was so fucked up was that I jumped a tooth. I read alot of posts saying that when they jumped a tooth their car idled like ****. I would have never thought to check this without you guys. Thanks alot guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmbsixteen »</TD></TR><TR><TD CLASS="quote">Thanks alot guys. </TD></TR></TABLE>
That's what we're here for...
