stalled
Old 08-11-2008, 12:40 AM
mogge's Avatar
Default stalled
Just about an hour ago I was driving home from work, as i stopped at a light my car stalled, and would not start... It makes the cranking noise.. but then nothing. I'm not entirely car savvy so I'm not really sure what to look for. I ended up pushing the car into a neighborhood until I can get back to it in the morning to see if I can see what I can do. Any ideas or suggestions are welcome!
I also did a quick search and didn't see anything that helped. Car is a 1992 Civic Si with stock d16z6 & dc header.
Old 08-11-2008, 12:45 AM
actek23's Avatar
Default Re: stalled (mogge)
sounds like the ignition coil went out in the distributor...
Old 08-11-2008, 12:49 AM
mogge's Avatar
Default Re: stalled (actek23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by actek23 &raquo;</TD></TR><TR><TD CLASS="quote"> sounds like the ignition coil went out in the distributor... </TD></TR></TABLE>
would that require a new distributor or is the ignition coil replaceable? as well how could i verify that is the issue?
Old 08-11-2008, 01:16 AM
* B A N N E D *
uoYkcuF's Avatar
any gas in it?
Old 08-11-2008, 01:26 AM
mogge's Avatar
Default Re: stalled (uoYkcuF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uoYkcuF &raquo;</TD></TR><TR><TD CLASS="quote">any gas in it?</TD></TR></TABLE>
yeah, i had a quarter tank left... unless it mysteriously disappeared?
Old 08-11-2008, 02:01 AM
* B A N N E D *
uoYkcuF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mogge &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, i had a quarter tank left... unless it mysteriously disappeared?</TD></TR></TABLE>
sounds ot me like you better figure it out before your car mysteriously disappears from that neighborhood.
if i were you i would not waste my time posting, asking questions. i would be searching, writing down/printing every single thing i could find.
then i would sort it from cheapest/simplest to expensive/complicated. then i would take my mysterious *** to the auto parts store, grab a few things, take a bag of essential tools with me (8-17mm sockets, few open end wrenches, pliers) and go fix my ******* car before someone fixes it for me.
Old 08-11-2008, 07:13 PM
mogge's Avatar
well i went back to the car today, basically it came down to the car having a blown ecu fuse.. after i replaced the 15amp fuse, it started for about a minute, but then died, and once agian didn't not start, but it didn't blow the fuse this time. I ended up replacing the dizzy cap & rotor, as well I replaced the ignition coil, once i replaced that it stated, went about 5 feet then blew the ecu fuse again.. I ended up using a 20amp fuse to get the car home (yes i know you're not supposed to use a higher amp than factory) . So any idea what could be causing the ecu fuse to blow?
Modified by mogge at 11:23 PM 8/11/2008
Old 08-12-2008, 03:47 PM
mogge's Avatar
Default Re: (mogge)
Alright, so I got the 15amp back in and was looking for a short or grounded wire and I came across the o2 which had oil on the 4wire connector.. So I assume it seeped in.. Anways I disconnected the o2 and it started right up and I had it running for about 5-10 minutes.. So im assuming that was the issue. Feedback is welcome
Old 08-12-2008, 05:39 PM
actek23's Avatar
Default Re: (mogge)
wrap the hole up with electrical tape and you should be good.
Old 08-12-2008, 05:51 PM
Seagull Management
94EG8's Avatar
Default Re: (mogge)
A honda mechanic once told me that sometimes the O2 sensor will feed power back to the ecu and the engine wont start, something along those lines anyway. thats the only time i've ever heard of anything like this.
torr
04-24-2024 09:35 AM
Unseen Racer
09-17-2008 11:07 AM
ActiveAero
09-16-2006 11:21 AM
ernald711
08-19-2003 12:31 AM
97civicdx
04-17-2003 03:09 PM
Quick Reply: stalled
