SRR LCA's
SRR LCA's
Just got mine installed on my hatch over the weekend as well as the Beaks kit with ITR rear swaybar. I noticed that they seemed that my car sits quite a bit higher in the rear now. Is this normal? Also the car handles allot better but creaks and groans like an old boat when cornering
Re: SRR LCA's (POS Hatchback)
when I put my sway bars in my '95, it sat up higher in the rear too. I guess it is normal. (hopefull) I had a pro install it. although mine was from Neuspeed.
1 Post
Did you lube the bushings ? that is where the noise is coming from.
A sway might make your car sit a little higher. Nothing that you can't adjust if you have coilovers
Re: SRR LCA's (im_poor)
Yeah is it preloaded??
loosen all the bolts and drop the car down on the ground tighten everything...should be fine!!!
OT: Lube t he bushings on the SRR?? I did no such thing, should I??
Blade_Irl
Suspension & Brakes
12-27-2008 01:21 PM
Hairy Hudson
05-14-2008 07:24 PM
