spring install
0epending on the tools you have and the condition of your vehicle... Lets say your vehicle is in good shape (meaning no rusted bolts) Since it is your first time it will probably take you around 4 hours.. After you have done it a million times it takes roughly 45 minutes if everything goes as planned.
Re: (nema741)
You'll need a spring compressor. Just rent one from Autozone. Other than that you just need some jackstands, a decent wrench set, a decent socket wrench set, and maybe a hammer for the rusty bolts. It will take you a few hours but once you've done one spring and shock the rest are a cinch.
Re: (BagelW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BagelW »</TD></TR><TR><TD CLASS="quote"> You'll need a spring compressor. Just rent one from Autozone. </TD></TR></TABLE> YES! 40 bucks which you get back after your done! Just be careful with them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BagelW »</TD></TR><TR><TD CLASS="quote"> maybe a hammer AND WD-40 FOR SURE for the rusty bolts. It will take you a few hours but once you've done one spring and shock the rest are a cinch.</TD></TR></TABLE> Definetely a nice start-off DIY-er. Make sure you cut both bumpstop's and dustboot covers if you are dropping more than an 1.5 in. Correct your camber as well and get an alignment if you value your tires. Good luck bro.
Re: spring install (binkster)
It is very easily a DIY project, however its always easier and more enjoyable if you get your buddies to help. For the times ive installed springs and shocks ive never used a compressor because i was too lazy to go out and borrow one. Just be careful if you decide to just throw a towel around the spring, THAT **** HURTS!
Re: spring install (seadonkeyraypiss)
Yea. one of my buddies is helping me, I have the jack stands im picking up the spring compressor tomarrow and were trying get my neighbor to let me do it at his house because he has a air wrench and all that other fun stuff that will make things go faster....
D3U1LT
10
01-12-2005 12:20 PM
All_JDM_Si
09-29-2003 11:00 PM
