spoon calipers
Re: spoon calipers (chad)
The Spoon twin-block caliper was originally designed for the larger front rotor of the DC2R (98 spec) and EK9. For EG, EK, and DC2 cars, the front rotor most be replaced. To help maintain proper front/rear brake bias distribution, the size of the rear calipers and rotors should be increased. Longer hub bolts and spacers will also be required. Clearance depends on the type of wheel, offset, and chassis. Please contact us for details.
Brake Conversion Kit
Part
Quantity
Twin-Block Caliper
2 (Left + Right)
15" Front Brake Rotor
2 (Left + Right)
14" Rear Caliper
2 (Left + Right)
14" Rear Brake Rotor
2 (Left + Right)
Front Brake Pad
Rear Brake Pad
Long Hub Bolt (+10mm)
Inner Spacer (T=5mm/PCD100)
Re: spoon calipers (Gump)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gump »</TD></TR><TR><TD CLASS="quote">
Part
Quantity
Twin-Block Caliper
2 (Left + Right)
2 (Left + Right)
14" Rear Caliper
2 (Left + Right)
2 (Left + Right)
Front Brake Pad
Rear Brake Pad
HOLY CRAP 15 INCH ROTORS?!?!?!?
Part
Quantity
Twin-Block Caliper
2 (Left + Right)
2 (Left + Right)
14" Rear Caliper
2 (Left + Right)
2 (Left + Right)
Front Brake Pad
Rear Brake Pad
Moderator
Re: spoon calipers (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
HOLY CRAP 15 INCH ROTORS?!?!?!?</TD></TR></TABLE>
no that is minumum wheel size...
memoryFAB.com representative
*droooollllll!!!!!*
*droooollllll!!!!!*
Moderator
Re: (Crispy Pickle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy Pickle »</TD></TR><TR><TD CLASS="quote">I'd be wary about caliper rebuilds and parts availability...</TD></TR></TABLE>
hmmmm...yeah OHKAY!
hmmmm...yeah OHKAY!
Solbros Owns Me
Re: (chad)
They will bolt onto any ABS spindle or Teg/Del Sol VTEC or 99-00 Si knuckle.
All you need is ITR or Prelude VTEC, the latter recommended, redrilled to 4x100, a couple spapcers, and you're money!
Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
hmmmm...yeah OHKAY!
Right...because these are Spoon calipers, they'll never require a rebuild down the road? Guess I should have gone ahead then and put the used set I purchased on my car even though one had a seal leak. Must have been all in my head right?
hmmmm...yeah OHKAY!
Solbros Owns Me
Re: (Crispy Pickle)
huh?
huh?
Re: (Emerika)
I was referring to Chad's comment above. I took it to mean he disagreed with what I posted earlier. Basically all I'm saying is it was a pain in the *** trying to find a rebuild kit for the Spoon calipers I had. While a new set might last quite some time, eventually it's going to need a rebuild and that, from my experience, is a pain in the ***.
Re: (Crispy Pickle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy Pickle »</TD></TR><TR><TD CLASS="quote"> I took it to mean he disagreed with what I posted earlier. Basically all I'm saying is it was a pain in the *** trying to find a rebuild kit for the Spoon calipers I had. While a new set might last quite some time, eventually it's going to need a rebuild and that, from my experience, is a pain in the ***. </TD></TR></TABLE>
obviously your not talking with the right people to get the rebuild kit... get in touch with ajr in canada.
they sell the rebuild kit for the two piece dc2/ek spoon calipers(not the monoblock)its about $85 bucks usdm.
so yes there is a rebuild kit for the calipers.. the kit starts with ek????? then numbers
