speedmeter is off
Old 09-19-2009, 09:29 AM
TOO MUCH TORQUE's Avatar
Default speedmeter is off
my friend just bought a 98 civic ex and the speedometer reading is off. for example, going 60mph, it will read 75 MPH and also the odometer and trip meter does not work but everything else does. Before spending money on a new used speedo, i want to make sure that it is the cluster that is broken, not some other sensor or reading unit
Old 09-19-2009, 09:38 AM
90Rexx's Avatar
Default Re: speedmeter is off
what size tires and wheels are on the car? how do u know what speed your doing if the speedo is off? answer those questions first ;-)
Old 09-19-2009, 09:39 AM
Amed Irizarry's Avatar
It Could Be The Speed Sensor On The Tran. But The Odometer And The Trip Not Working Sounds Like The Cluster Is Bad Or Going Bad To Me.
Old 09-19-2009, 11:56 AM
duwa's Avatar
just like 90 rex said, in order to get the right reading you need to have the stock rims/ tires or something similar to OEM size, having over/under size rims/tires will give you a different readings example= if ur car comes with 16" and you put some 14" rims with low pro tires, your reading will be faster than what you are actually going.
anyways.
dont use the police speed trap cuz they go wack once in a while. and dont compare your car with ur buddy's riced-out civic cuz he may have a bad reading too.
Old 09-20-2009, 12:32 PM
i am using my garmin gps which is about as accurate as it gets.
for sure i know the speedo is off because, when i shift from 1 to 2 at 3k rpms, the speedo is reading at 25-30mph already...
the car is rolling on 14 inch steelies
toeKNEEohh
09-24-2011 12:22 PM
lechuza05
07-22-2007 10:22 AM
custom session
22
05-19-2007 06:31 PM
503_EF9
05-14-2007 08:31 AM
SOHC4life 96
03-09-2004 08:21 PM
Quick Reply: speedmeter is off
