Spark Plugs
Spark Plugs
Something weird happened when i was driving home from work today. Car started to bog out,sounds something like this, bog,bog,bog and drive,bog,bog,bog and drive. Friend told me today he saw white smoke coming out the exhuast. So i took out my spark plugs and noticed a lil white on the tips,What could this be,and how mite i fix my problem, Buy new plugs??
Re: Spark Plugs (Scantron)
i could be wrong on this but i always thought white smoke, is from a head gasket, like radiator leak maybe? our legend had the same problem when start up, white smoke we replace the head gasket and that fixed the job.... i hope that helps
Re: Spark Plugs (JDMFreak)
So by replacing the head gasket should work out than eh. What head gasket would i need for a 96GSR bottom head and a B16 head??
I would do a compression test to be sure that the headgasket is at fault. if that is the case, either a B16 or a GS-R one will work fine because they are the exact same.
HT Order of Merit
Re: Spark Plugs (Rev2Eight_EM1)
I could be mistaken, but it sounds like a fuel issue... a headgasket wouldn't make a car "bog" unless it was completly blown, and it wouldn't just return to normal.. it would bog and get worse until you can't go anywhere.
Re: Spark Plugs (JDM_Ej)
http://www.beru.com/english/pr...e.php
http://www.eric-gorr.com/techa....html
http://www.off-road.com/dirtbi...3.jpg
http://www.off-road.com/dirtbi...4.jpg
which one is it? a bit of gray could mean running ok, some white means deposits...running rich maybe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">I could be mistaken, but it sounds like a fuel issue... a headgasket wouldn't make a car "bog" unless it was completly blown, and it wouldn't just return to normal.. it would bog and get worse until you can't go anywhere.</TD></TR></TABLE>
or that. running lean would result in white plugs i believe
If the head gasket has blown it can push water into the cumbustion chamber of the cyliner closest to the breech, which "steam cleans" the plug tip. White plugs can indicate a head gasket failure. Run a compression test!
Modified by tpr at 12:34 PM 2/3/2006
Well im kinda leanin to the bad gas problem. Very weird when the day i change my gas from 94 to 91 this problem coems across. Going out today to get rid of the 91 and freshen it up with 94. Ill go in DET 4 My HONDA
hatchydude
04-29-2009 09:54 PM
gray_civic_coupe
01-16-2006 03:15 AM
