something hissing after car is shut off (video)
im not sure if this is normal but when i turn my car off it sounds like a air leak coming from my brake booster area I'm not sure actually maby power steering but it could be making that noise while the engine is running too i wouldn't be able to hear it
it makes the noise for about 5 seconds after the car is off and then stops heres the link to the video.. might have to turn your volume up a little
https://www.facebook.com/photo.php?v...42027082894512
Re: something hissing after car is shut off (video)
I had this leak a minute ago. Check the hose clamps on the lines to and from the booster to manifold. I tighten them all a bit and all gone. No more leak for me
nope doesnt seem like its those hoses.. its frustrating i cam hear it but cant fint it.. sounds like its coming from the master
could you be a little more specific with the pic as to where the leak is coming from. in your pic it looks like a massive crack below the MC.
If that is teh case i think you will need a new brake booster. or did you find the leak coming from right behind the MC where it bolts up to the brake booster?
if so then i would say it is not sealed properly. but the details area little vague.
please be a lil more clear. and specific
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
um, the master isnt sealed to the booster, thats a dust seal, the rubber piston seals in the booster are sealed inside, when you push on the brake, you push on the rod in the booster,which pushes another rod, that operates the master, if the booster failed, you will still brakes, the pushrod in the booster acts directly on the master pushrod
it's air possibly leaking in, there is no pressure in the booster, if the diaphragm is bad, air will try to make it's way back into the booster diaphragm, if you pull the master cylinder and see fluid where the rear seal on it is, then it's probably leaked into the booster, and ruined it.
JDM JUNKIES 1
03-12-2013 12:19 AM
GroundZer0 336
11-19-2003 01:36 PM
