Someone said i gotta leave the stock stereo in????
Old 12-26-2002, 02:28 PM
InjectedSS's Avatar
Default Someone said i gotta leave the stock stereo in????
im wanting to remove the stereo to put in a better one of course in my 00 civic and someone said that if i do my keyless entry wont work? can someone comment on this? thanks
Old 12-26-2002, 02:32 PM
Spade's Avatar
Default Re: Someone said i gotta leave the stock stereo in???? (InjectedSS)
False.
Old 12-26-2002, 03:25 PM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: Someone said i gotta leave the stock stereo in???? (Spade)
False, supposedly Circuit City sells a kit that will allow you to remove the OEM stereo without having to sacrifice the keyless entry system.
True, the wires behind the stock stereo are for keyless entry, with the stereo installed to close the circuit there will be no keyless entry. I believe the keyless entry brain is all green and rests in-between the stereo. Should be viewable with the stereo pulled out.
Old 12-26-2002, 05:13 PM
New User
WiZeBaNaNa's Avatar
Default Re: Someone said i gotta leave the stock stereo in???? (SHAUNTS99)
what shaunts99 said is true for 96-98?...
for 99+ you can, and i did, retain keyless with an aftermarket headunit... honda moved it for 99
EDIT: put in a space...
[Modified by WiZeBaNaNa, 6:13 PM 12/26/2002]
Old 12-26-2002, 05:18 PM
INVALID's Avatar
Default Re: Someone said i gotta leave the stock stereo in???? (WiZeBaNaNa)
I stand corrected because I was referring to 96-98, I forgot to take into exception of the 99-00 Civic.
Old 12-26-2002, 05:28 PM
Civichatch2k's Avatar
Any reputable stereo shop will be able to make it work with whatever stereo you choose.
Old 12-26-2002, 06:09 PM
qcoffey's Avatar
I also removed my factory head unit and retained the keyless entry.
Old 12-26-2002, 08:21 PM
InjectedSS's Avatar
Default Re: Someone said i gotta leave the stock stereo in???? (Civichatch2k)
not like id be takin my **** to some dumb ****** at a stereo shop to let them **** my **** up neways guys thanks for the info, looks like it should be fine then
Old 12-26-2002, 09:04 PM
ShortbusEK's Avatar
only the 96-98's had the damn keyless **** built into the radio (it sucks!!).. an 00 civic will be just fine.... I install the mobile electronics for a living at best buy...
Old 12-26-2002, 09:33 PM
JforJonathan's Avatar
hey i got that same question, i think its true though. i asked a shop around here. they said i gotta leave it in. unless you wanna get an alarm with keyless entry.
Old 12-26-2002, 09:38 PM
InjectedSS's Avatar
Default Re: Someone said i gotta leave the stock stereo in???? (SiKick)
once again this is why u ask here from people that KNOW and not some moron at the stereo shop
Old 12-26-2002, 09:57 PM
DV98CVC's Avatar
...so in conclusion, 96-98 you have to keep your stock unit in, and 99+ you don't have to, correct?
Old 12-26-2002, 10:25 PM
INVALID's Avatar
Default Re: Someone said i gotta leave the stock stereo in???? (DV98CVC)
Take out the comma, the word "correct", and the question mark and there lies the answer.
Old 12-26-2002, 10:38 PM
TurboBumblBee's Avatar
96-98 keylesss is controlled by the headunit.. buy a 801720t and you can keep the factory radio in the car and keep keyless entry.. 99-00+ doesnt matter if you remove the factory radio keyless entry will still work..
Old 12-26-2002, 11:29 PM
BagelW's Avatar
...so in conclusion, 96-98 you have to keep your stock unit in, and 99+ you don't have to.
There you go.
khenning
16
12-27-2010 10:25 AM
VTEC_Viking
Audio / Security / Video
07-24-2009 09:57 AM
oovvutt
10-09-2008 06:36 PM
Travis2262
06-15-2007 08:43 PM
boflex
06-10-2005 08:32 AM
Quick Reply: Someone said i gotta leave the stock stereo in????
