Soft spring rates with 22mm rear sway bar?
I currently have Tein RA's with 14kg/mm springs in the rear and a 22mm ITR rear sway with the Beak's subframe reinforcement kit. I will be putting stock 2000 Civic Si dampers and springs on a couple times a year for comfort reasons and i am wondering if i should be worrying about tearing out my subframe with the softer springs, because that would really suck. Thanks in advance.
Greg
Greg
1 Post
Re: Soft spring rates with 22mm rear sway bar? (:hammer:)
Re: Soft spring rates with 22mm rear sway bar? (navin)
OK mister civic ground control rates
EDIT: If any body has usefull info, please share it
[Modified by , 8:35 PM 2/2/2003]
Re: Soft spring rates with 22mm rear sway bar? (96 SOHC VTEC)
is the reinforcement kit THAT good that you would have nothing to worry about?? I run some fairly soft spring rates (H&R OEsport) and have been contemplating getting the beaks kit with ITR bar.. but still not convinced that it's enough ...
Re: Soft spring rates with 22mm rear sway bar? (sil)
sil,
search, and you'll find lots of threads stating an overabundance of satisfaction from the itr sway and beaks and bsq kits. Some state that they have been driving really hard with the kit and no damage resulting. I'm doing pretty soon. I just searched yesterday for like two hours on the subject.
Anthony
Anthony
The Beaks kit is great, and why would soft spring rates have anything to do with sumframe tearout? If anything, hard spring rates would effect it more, and if no one is having tear out on hard springs with reinforcement kits, then I believe you are in the clear.
Re: Soft spring rates with 22mm rear sway bar? (E-H-2)
sil,
Anthony
Anthony
coblankenship
24
06-03-2014 09:12 AM
deviant1
15
04-21-2006 06:10 PM
deviant1
08-25-2004 07:23 PM
ion_four
04-20-2003 08:45 PM
