so u want torque huh?
i wanted to get a little extra power to my wheels so i bought a clutchmaster stage 2 and i went to have it put in then i sent to have my friends pick my car up.....so of course they were "testing out" the new clutch.......until one of them tried to slam second gear and the damn shif linkage fell out to the ground......turns out i was missing an AC bracket that served as a motor mount and the clutch gave so much torque it twisted the motor and cracked the trans case .....i don't suppose this has happend to anyone else? .......last time i EVER let anyone drive my car other than me..........
Re: so u want torque huh? (wilsel)
well.....my friend is giving me his 2000 si tranny and i am gonna split the cost of a new (used) one with him.....i was going to put the bracket on as soon as i got home......it proly woulda happend to me but i baby my car and i knew u were supposed to break them in so i don't know....
Re: so u want torque huh? (h82lose2vw's)
which brings me to my next point.......could u guys tell me anything about an si on a GSR better or worse....i know it has shorter gearing but how does it handle the higher revs and such?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel »</TD></TR><TR><TD CLASS="quote"> Your supposed to break it in anyway for 500 miles, but you would of probably done the same thing later on.</TD></TR></TABLE>
never 'test out the new clutch' just as it has been put in...
Tthe Si tranny will actually make you perform better because it is tighter geared. It will work perfectly. You will definatly notice an improvment for the better.
Re: so u want torque huh? (PhatHardy)
I thought CM stage 1 and 2 don't require a break in period?
They told me only stage 3 requires break in.
As far as your a/c mount...I ran my car for over a year without that mount and never had a problem.
Re: so u want torque huh? (hot_EG)
wow.....it wasn't just that mount though .....the retarded immigrant that put my motor in didn't bolt down another mount and i didn't even notice it was the trans mount .....so i was missing 1 and a half ......it was bad.....i almost cried
spock_rocker
10
07-30-2005 05:17 PM
