So I thought I knew what mounts I needed......
I have a JDM B18c sitting in my garage thats going to go into my EG. As far as I knew, I could use any b series mounts provided they were off a 94+ integra and not off of a 99-00 SI. So i went and bought a set of type R mounts figuring they would work. Wrong. Drivers side doesnt line up. Then, I get the mount off of my buddies Integra LS figuring it would work. Wrong again.
So now I'm confused. What mounts do I need? The mounts that I have have the two bolts for the mounts directly across from each other. The bolts coming off of my motor are offset with the one closest to the front of the car being about 1/2" more to the right than the rear bolt. Kinda looks like \ with a bolt being at the top and bottom of the forward slash. So, anyone out there have any idea?
Re: So I thought I knew what mounts I needed...... (JapTendencies)
bump cuz I dont have a car after friday and I need to get this running. Anyone?
For the top tranny use stock civic mount or 94-01 integra mount use integra 94-01 rear bracket and it sounds like you need a 2 hole drivers side bracket just use the stock civic drivers side mount it will work.
