Help, removing lower timing belt cover
Help, removing d16z6 head
I am in the middle of removing the head in favor for a ported and polished one, with a zex 59300 cam. I cant seem to be able to get a wrench on the bolt near the crank that holds the cover. Does anyone have any tips from doing this in the past?
thnx ahead of time
Modified by 94exguy at 8:25 AM 6/1/2005
thnx ahead of time
Re: Help, removing lower timing belt cover (94exguy)
Have you taken off the crakshaft pulley, don't know what engine you have but on by b series you have to take off the pulley to take off the lower cover if I remember correctly.
sorry guys its a d16z6 i was trying to avoid taking the crank pulleys off but i guess if i can't find another way....thnx for the replys
u dont need to take that cover off to remove the head
removing the head just includes removing any vac lines/etc from the head, the bolts inside the head, and slipping the timing belt aside
just set your head to TDC, mark the belt, slip it off and hold it up with some wire... set the new head to TDC and mark it the same place u marked the other one.. and put it on slide the belt on
when we replaced my HG in my z6, we did not need to remove the lower timing belt cover
Re: (Morning Call)
Ya i figured i'd might as well change the timing belt because it was changed last at 75k now at 150k thought might as well. Yes i know the previous owner did change it early but ohh well. thnx for the help i'll try again tomarrow and see if i can get it
Re: (94exguy)
Well i deicided to just change the timing belt later, but i can't seem to loosen the adjusting bolt which is in a rough spot. I'm using a ratchet and a pipe on the handle as getho breaker bar/extension. The socket just keeps slipping off and i'm scared im just stripping the bolt which would be muy no bueno. An air ratchet can get on in and stay on it but doesnt have torque to loosen it. Does the adjusting bolt really have to come lose to just switch the head, I mean it does make sense that it would have to but if it didnt that would be so much easier. Now second day on the project and i'm running out of knuckles to bust up.
flood
06-20-2008 03:10 PM
