Smoking Problem
Old 07-23-2007, 09:53 PM
95civic16's Avatar
Default Smoking Problem
I just bought a 1995 civic coupe and before i bought it the car had a blown head gasket and it was replaced before i bought the car now whenever the car gets hot the white smoke comes back again what is the problem? Anything will help thanks
Old 07-23-2007, 10:06 PM
I took way too long
slowman's Avatar
Default Re: Smoking Problem (95civic16)
Well what do you mean when the car gets hot? Does the coolant gauge go up higher than normal? If so, probably time to take the head back off, test for warpage, then put it back on with new headgasket.
Old 07-23-2007, 10:09 PM
95civic16's Avatar
Default Re: Smoking Problem (slowmanEK)
No the temp. stays the same all the time it seems like when the exhaust gets hot the smoke comes
Old 07-24-2007, 12:12 AM
elmo908's Avatar
how long have you run it with smoke coming out. Did you just have the head gasket done and it started doing this or what? Is it running poorly? and are you losing coolant?
Old 07-24-2007, 11:09 AM
95civic16's Avatar
Default Re: (elmo908)
The Car runs great the coolent level is good idk what it could be.
D3vin
14
03-14-2010 08:41 PM
andyvaj
11
09-18-2008 11:16 PM
garageEF
02-14-2008 07:35 PM
prendi
08-22-2003 02:10 PM
Quick Reply: Smoking Problem
