My car won't start when I turn the key in the ignition.
Re: My car won't start when I turn the key in the ignition.
try jumping the starter, un plug the female end that goes on the starter, grab a piece of wire and touch the power wire with male end of the solenoid, with the ignition on. If it doesn't actuate starter went out. Hope this helps
Have you tried charging the battery or jumping the battery. If battery is known to be good then follow what Monstrosiybl suggested.
If starter fails test consider buying a used one from junkyard..should be around $25 -$40 with core (old starter).
