My car won't start when I turn the key in the ignition.
Old 04-24-2017, 12:09 PM
FF4JoeJ's Avatar
Default My car won't start when I turn the key in the ignition.
I can hear a clicking in the fuse box on the passenger side of the driver when i try to start it.
Old 04-24-2017, 06:08 PM
Monstrositybl's Avatar
Default Re: My car won't start when I turn the key in the ignition.
try jumping the starter, un plug the female end that goes on the starter, grab a piece of wire and touch the power wire with male end of the solenoid, with the ignition on. If it doesn't actuate starter went out. Hope this helps
Old 04-25-2017, 02:06 PM
Jimi Hondrix's Avatar
Have you tried charging the battery or jumping the battery. If battery is known to be good then follow what Monstrosiybl suggested.
If starter fails test consider buying a used one from junkyard..should be around $25 -$40 with core (old starter).
mdrouillard1983
06-06-2014 05:24 PM
gooblinn258
12-16-2013 08:23 AM
ThaSpitefulWun
19
10-05-2004 12:14 PM
EF9 JAMS!!!
09-23-2004 10:21 AM
vtecdc2
12-01-2002 11:35 PM
Quick Reply: My car won't start when I turn the key in the ignition.
