Slave Cylinder Problems!
HEy guys, i have a 1992 cx hatch. My slave cylinder is going out...the one on the fire wall. I was wondering how hard this is to replace. I know there are two bolts on the pedal side of the fire wall. But is there anything i should be aware of? is it going to leak fluid all over my carpet and what not? Also how do i bleed my line off that one? thanks in advance.
New User
Re: Slave Cylinder Problems! (Rev-Olution)
The one on the firewall is the Master cylinder.
Not too diffcult to replace, make sure you have wrench extensions for rebolting down behind the pedals, it might be a pain to reach. It was for me.
EDIT: We talking about clutch correct?
New User
Re: (Rev-Olution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev-Olution »</TD></TR><TR><TD CLASS="quote">yah its the clutch. How hard is it to bleed the lines, and about how much fluid should i buy.</TD></TR></TABLE>
Not hard to bleed, I wrote a good article a while back... Use search for 'how to bleed clutch'. You will only need only one containter of honda brake fluid, any fluid will work, however I prefer honda or ATE...
New User
Re: (976)
Here is a good link: https://honda-tech.com/zerothread?id=491080
Just in case you didn't know, you bleed the clutch fluid system from the slave cylinder... Good luck!
Duck Sauce
04-13-2008 09:30 PM
