CLUTCH INSTALL.......help
Ok guys and girls,
this weekend i will starting my clutch install, can anyone lead me to some online walkthroughs, instructions, tips anything? has ANYONE done a clutch install, is it difficult could you offer tips or anything? i am a bit nervous and want some ease of mind......i have the helms manual! help!
Re: CLUTCH INSTALL.......help (NYb16)
hah, i'm in the middle of installing my clutch right now. i just put on my JUN lightweight flywheel and i'm about to put on my ACT clutch but couldn't finish the project tonight because i don't have any super high temp grease. damn it!
as for a site that was really helpful for me: http://www.c-speedracing.com. it is fairly easy but, let me warn you, you have to remove a lot of **** before you can remove the tranny (especially if you're turbocharged). oh yeah, removing the axles are a bitch!
Re: CLUTCH INSTALL.......help (boostedeg6)
removing the axles should be a breeze, popping the pin out of the shift linkage will be the most difficult part
get a helm's manual, it really is worth its weight in gold
Just a note. You can disconnect the shift linkage at the shifter itself. I found this easier than getting that damn pin out at the trans end of the shift linkage.
Re: CLUTCH INSTALL.......help (ck279)
he's rite. it is easier to get the pin out of the trans end of the shift linkage when u disconnect the shift linkage at the shifter itself :]
integrakilla
04-28-2004 12:47 PM
