skunk2 vs blox
skunk2 vs blox
which coilover set up would be better skunk2 proS or blox street series. and when i mean better i mean good handling and the ability to allow for some slamage
Re: skunk2 vs blox
Koni Yellows (or Blues) with GC Coils. Ha ha. Slamming depends on your budget. I wouldn't go more than 2" - 3" deviation from the standard deviation from stock. That is my opinion though and I like the ability to go over speed bumps head on, ha ha. As for your original question, I'd go with the blox.
Re: skunk2 vs blox
See, when I bought mine it was pretty low, the front lip was about 4" off the ground and I scraped everywhere. Lost a few pieces of the front bumper to manhole covers and pothole combos. It looks neat but it is very impractical. If I had decent pics I would show you. In addition, I know I suggested a two piece set up but for overall ease of install I would look into full body coils.
Re: skunk2 vs blox
Check these out https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/progress-coil-over-special-promotion-2692801/ these guys have been doing suspension a hell of a lot longer than Skunk2 or Blox, and they ride good plus the price is nice.
Re: skunk2 vs blox
well i know the skunk2 setup only has spring adjustment and not to sure on the spring rate but the blox has perch adjustment and spring adj and their spring rate is 10 kg/mm in the front and 8 kg/mm in the rear
Re: skunk2 vs blox
ive got the skunk2 proseries full coilover setup and its awesome...the spring rates are kinda high but with the adjustable dampening it about even things out...and im pretty low i dont hav any pics of my car with them on there yet but im tuckin some good tire
Re: skunk2 vs blox
i agree ive had both setups right now im ridding on blox i had skunk2 proS coils but they werent as stiff as the blox and you could only adjust spring height
Re: skunk2 vs blox
well u have different options with gc/koni. u can get the koni yellow and gc sleeves for 799 but u have to re use the stock top hats. or u can get 2 front top hats for 899 or i did i got all 4 gc tophats and it was 1055 shipped from gc.
Re: skunk2 vs blox
whats the the spring rate on these
Re: skunk2 vs blox
X2 on the ground control setup I'd highly recomend them I got mine for 899 shipped with front tophats from THMotorsports. My car is pretty much slammed and you cant even tell it rides just that good. I got the "race" rates which are 480 front and I forgot what the rear was. If your going to slam it then dont get the base rates. People in the salmmed thread are running up to 550 in the front so that you dont bottom out on holes and dips.
Re: skunk2 vs blox
i have both collars taken out of the front of mine i cant get it to go any lower and the back is as low as it will go with the collars in
Re: skunk2 vs blox
Mines maybe just a tad bit higher than that but I also dont have a lip or sideskirts and I still have room to go lower. I'll have to get some pics up.
