SiR I and SiR II question
Re: SiR I and SiR II question (projectEK9)
http://tech.hybridgarage.com/tech/b16/index.html this site will help you better than i can explain it
Re: SiR I and SiR II question (allmtr)
-Absence of a PGM-F1 label on the intake manifold.
-The Intake manifold has no bulge on the back side (side facing the firewall).
-Connector plugs on the engine harnesses are grey instead of milky white.
-Absence of vacuum dashpots on the intake manifold and throttle body.
-MAP sensor is an integral part of the throttle body, not an external one with a tube.
also p30 pistons internally, hydro tranny
Re: SiR I and SiR II question (akumaracer)
well if you wanna check the valve cover the siR has DOHC vtec ...dohc being larger than vtec..adn the siR II has dohc VTEC....vtec being larger than dohc....but it doesnt help if they change the valve cover
hondahead21
05-04-2008 04:52 AM
