si 2 gsr ??????
Re: si 2 gsr ?????? (hotdoggies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotdoggies »</TD></TR><TR><TD CLASS="quote">Will they be worth the effort power wise?</TD></TR></TABLE>
no
no
Re: si 2 gsr ?????? (Spade)
thanx man u have been a lot of help!!!! man iam just tryin to find parts you know 4 just a lil more speed/acceleration. getting desperate you have any ideas???????
ya i got a jdm b16 with gsr cams, soo ya it will work. i mean its prolly gunna do about what any other bolt on will, about 2 or 3 horse power, i got mine from a friend for 10 bucks so i thought id do it
Re: si 2 gsr ?????? (Aespooncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">u take off the valve cover and slap those bitches in the old ones just unclip and u clip the new ones in easy as that </TD></TR></TABLE>
Modified by IC33 at 2:28 PM 2/22/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aespooncivic »</TD></TR><TR><TD CLASS="quote">damn i forgot about those after that ur cool u can just clip em in and run em no prob
thanks IC33 for clearing it up </TD></TR></TABLE>
dont post anymore cause your useless
heres a great write up on g2ci thats should be alot of help
http://www.g2ic.com/tegtips/en...l.doc
good luck
good luck
Re: (PHOBIA)
just get some b16b cams in there , and to whoever is talking like a complete retard on how to install these as stated please stop posting, there has to be a cliff around where you live to jump off of.
Re: (hotdoggies)
You're gonna need a torque wrench because the plates that hold the cams are torqued to a specific spec. You also need to know how to set the timing belt. IMO its not worth it unless you atleast get some type r's or if the gsr's are really cheap.
sorry, its not.
sorry, its not.
Re: (93gsrcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gsrcoupe »</TD></TR><TR><TD CLASS="quote">You're gonna need a torque wrench because the plates that hold the cams are torqued to a specific spec. You also need to know how to set the timing belt. IMO its not worth it unless you atleast get some type r's or if the gsr's are really cheap.</TD></TR></TABLE>
don't forget you need a feeler gauge for setting your valve lash too.
Re: si 2 gsr ?????? (JDM alphanumeric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM alphanumeric »</TD></TR><TR><TD CLASS="quote">waste of time.</TD></TR></TABLE>
ya pretty much, just get some good aftermarket cams and valve springs or type-r cams if you can find em cheap.
