Should I replace pistons with if I install a turbo on my B16A
upgrade the fuel pump. Fuel pressure regulator. MSD ignition so u can retard the timing. would be wise to get some lower comp pistons if u plan to boost over 9 lbs. if u go over 9lbs then i would get some new injectors.
Might wanna check out the Forced induction forum and run a search
TurboCivicSIR
04-05-2004 06:26 PM
