SHIFT POINT RECOMENDATIONS??????
I am just wondering where you guys might be shifting while at the track. and what you might suggest i shift at with my setup. see sign for setup. i was shiffting at 7000 but this weekend i was messing around and found that it seems to still pull after 7000. but with the stk rods and rod bearings and a6 pistons in the z6 block i dont know if i should go any higher. what are your suggestions. flame away!!!
i recommend that u shift right before redline u will pull the best times that way shifting is a process and all processes take time.. which will lower ur track time i had a sohc vtec zc motor redline was 7200... that is when i shifted and i could pull a 16.8 and i am a mile up in altitude check alb dragway.. new mexico..
Re: (pane93civhb)
true, but the people at zex and the machine shop said that this head will create power from 3000 to 8500 rpm, i know better than to go to 8500 but do you think the motor will handle 7500-8000?
yea if ur motor is built like that im sure it will be ok around that point and if u have it chipped it will be ok i think u should slowly push it just a bit ... u no to test it out..
LankorDie
24
02-28-2005 09:25 PM
