shift linkage or shifter problem!?
My buddy just got done with a swap... d16y8 w/ z6 tranny in 93 civic. After hooking up the shift linkage the shifter was sitting far to the right I went over there to check it out but still cant figure it out? 1st gear is almost where 3rd should be and when in the middle (neutral) its slanted toward the passenger side... any suggestions? Thanks in advance
Re: shift linkage or shifter problem!? (aznej2)
check the shifter seating which is #11 in the pic shown below and also check all the bushing and make sure #26 is tight and check all the bushing. and also check if the end of the shift rod and extension are hitting against chassis
G0crxG0
40
04-24-2006 07:14 AM
BDogggUT34
38
04-11-2005 02:19 PM
