S300j problems Car running in permanent limp mode
I just got back with my GSR ecu which i had the S300j installed in.
When the guys installed it they had a problem with the laptop reading the ECU on 2 cars but when they reinstalled the software then the laptop reconised it. However/while it was giving this problem they thought it was the socketing, so the guy took it and did what he called a "circuit test" and said that the ECU is fine.
During the testing process I saw a solid red light, but when i asked what it was they told me that i would see a red light before a program is uploaded.
Now that i have gotten home and plugged the ECU into my car i still see the red light so i uploaded a program but the check light stays on, then i start the car, it idles at 1500 rpm and limits at 3500rpm. I tried different programs, and nothing. The CEL stays on constantly. I cant datalog or nothing. nothing works. I dont live close to where i had it installed actually i live thousands of miles away ( in different countries) and really cant afford to ship it out and be without the car for extened periods since i just finished my vocation and i am goin back to work nextweek, and the car is my daily driver.
Is there anything that i can do here that could solve my problem?
In the install manual it says remove J4 resistor and transfer to J1 ? does the resistor need to be there or can there be a thin wire acting as the jumper?
Is there anything else i should look for/look at ?
Can i test for continuity between any contact points to check to see if the board(s) are working correctly?
The ECU was working perfectly before, so i know it works.
Need Help ASAP
Oh the car is a Civic with a B18C swap with P30 pistons, stock head, no cams yet and stock P72 ECU
Need Help ASAP
Re: S300j problems Car running in permanent limp mode (eg6madness)
Check the plug from hondata to the ecu. Had the same problem and one of the pins on the hondata box had broken and had to have it soldered back on. there is a jumper wire that you can cut to make the ecu go back to stock but i dont know exactly which one it is. I think j4.
eg6madness
08-16-2007 10:31 PM
