?'s for 450cc precision injectors
i was just wondering if i buy the 450cc precison injectors and install them on a my car will i need to modify anything besides installing a resistor box. its a b16a2 motor.mainly just a chipped p28 and stock manifold in 94 civic coupe the ex model.
Re: ?'s for 450cc precision injectors
you'll need to have ecu programmed so that it knows the injectors are larger than stock.
oh okay thax.im going to look on that. but do you know if i need anything like for example larger clips for the larger injectors. or maybe new o rings because this harness came out of a d series motor
you'll need OBD1 injector clips i believe
o-rings should be fine unless they're worn out
and if you get the high impedance ones, you don't need a resistor box
thax trust.... im actually getting hold and peak injectors so i will too need resistor box.oh i c so you dont need bigger clips or different o rings. well i hope to buy those injectors and hopefully things fit to ease.thax
FMIDRC Racer
05-13-2005 06:00 PM
