Running on two cylinders........help.
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">ya. get a B series </TD></TR></TABLE>
thanks for the bump at least.........i think the z6 was fine
400$ for a complete swap.......yeah, the z6 is fine.
It was running fine before I did the stuff above. It had
a few check engine lights I hadnt fixed yet, but it ran ok.
any help.......thanks
Re: (elwood)
yes. i feel the same way. been hanging out elsewhere lately.
i have no idea why you're having this problem, and i know this is a completly retarded suggestion, and i know you're better than this but: do you have the firing order correct
Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">yes. i feel the same way. been hanging out elsewhere lately.
i have no idea why you're having this problem, and i know this is a completly retarded suggestion, and i know you're better than this but: do you have the firing order correct </TD></TR></TABLE>
Yes this place has gone Down Down Down, EG+ is goin down.
On a lighter note, jwn7 is probly right. do you know what 2 cyls are not firing? Are you getting spark on all of them? In the dark, if you crank the car, are the wires arc-ing bad? You could have swaped the 2, and thats why they are not working...
Re: (xerox445)
i said that because the last time i changed my cap and rotor, i mixed up cylinders 2 and 3 on the dizzy. the motor started ok, and it did actually run (like crap), but it was shaking like a bitch due to the dual misfire. then i switched them and everything was cool.
Re: (jwn7)
with even one cyl mising, my motor shakes like a mo fo...but that could also be because my mounts are falling out, and my rear tranny mount is cracked on the case...i should get that fixed, huh
Re: (xerox445)
well, at least I got some replies this time.
I was positive that I had them right, but what you guys are saying
is giving me my doubts. Its # 2 and 3 that arnt firing. So what is
the proper firing order.........?....I guess I could look in the helms.
Re: (elwood)
you right about this forum go to ****, anyway back to your problem. did you bleed all the air out of your coolant system? check the plug at your dist. to see if you tight?
Re: (JDMlifestyle)
why?
why?
Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">
why?</TD></TR></TABLE>
because he obviously dosnt know the answer to any of my questions,
and for some stupid reason he decided to ***** my thread.
to all the other sugestions, I dont think its going to be that easy.
I have tried so many things........I am seriously at a loss here.
Spade
158
12-05-2003 02:51 PM
