running on cylinders 1 and 2
Its a 2000ex with a D16z6, y8 intake manifold,y8 dizzy guts inside z6 dizzy housing. I have spark on all four cylinders and not to sure about fuel. Throwing a 14 for iacv. Im pretty sure that its only running on 1 and 2 because idle doesnt change when I pull the wires on 3 and 4.My question is could the fuel filter cause this if the car sat over a year?? And how would i check to see if the injectors are working properly? This set up worked prior to a new engine harness install.
Re: running on cylinders 1 and 2
running a Z6 on a Y8 cam? I'm not sure but does that work?
I ask because this is the second time i have heard of a y8 head on a z6 block with only 2 cylinders firing, 1 an 2.
StuckInTexas
02-12-2015 10:38 PM
TheDrizzle50
21
09-21-2007 04:23 AM
