running on 3 cylinders
94 civic
my second cylinder from the cam gear has no compression...i dont know what might be the problem...the car still runs and runs smooth....i check my injectors and harness and they were fine...also check my spark plugs and spark plugs wires and there are fine....so what can be the problem......
Re: running on 3 cylinders (xmonkiix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xmonkiix »</TD></TR><TR><TD CLASS="quote">94 civic
my second cylinder from the cam gear has no compression...i dont know what might be the problem...the car still runs and runs smooth....i check my injectors and harness and they were fine...also check my spark plugs and spark plugs wires and there are fine....so what can be the problem......</TD></TR></TABLE>
Before you start getting people confused.
The cylinder you are referring to is cylinder #3, easier reference so pple know.
So you have absolutely NO compression and the car's running 100%?
Seems like you screwed the test up.
Are the spark plug threads screwed up at all?
SiBuddy00
16
09-10-2015 01:59 AM
FA Q RACING
Honda Motorcycles
08-25-2003 08:02 AM
