Rubber Boot Identification Help
I have two rubber boots with grease that tore during my swap ( mostly due to i forgot how to remove the axles and accidentally removed the tie rod end ) but i dont know the name of then. One is at the bottom of the steering knuckle ( the one you remove to remove your axle ) and the one on the end of the tie rod end. Its on the tip of my tongue but i cant remember.
Re: Rubber Boot Identification Help
Did you successfully change out your half-shaft?
So with your ball-joints your referring to your lower ball joint which is located on the knuckle and the tie rod end.
This website has the boots you are referring to for $3.00 + however much for shipping.
Here is a link to a parts list for a 1994 Honda Civic EX,
Here is lower ball-joint boot
http://parts.sonshonda.com/showAssem...&searchString=
Here is tie rod boot
http://parts.sonshonda.com/showAssem...String=tie rod
I only have it saved because it was the only website i found so far that has bolts for sale whenever i ruin them. But other then that have never ordered from it because its too expensive and you can find it elsewhere for cheaper.
Another website that you can check is Majestic Honda or something, Ive been referred to it several times on this forum.
http://parts.sonshonda.com/showAssembly.aspx?ukey_assembly=282614&ukey_make=9 88&ukey_model=13654&modelYear=1994&ukey_category=0 &ukey_driveLine=6280&ukey_TrimLevel=12108&ukey_mod elRange=0&searchString=tie rod
is this the same thing? i have a few more parts to order form nopi
http://nopi.com/dsp_parts.php?vsubpcdesc=Suspension%20|%20Ball%20J oint%20Boot%20Kit
http://nopi.com/dsp_parts.php?vsubpcdesc=Suspension%20|%20Tie%20Ro d%20Boot%20Kit
kroze
01-02-2006 06:20 PM
