RPM JUMP AT 1500
Old 03-31-2016, 06:23 AM
Asaf's Avatar
Post RPM JUMP AT 1500
Hello
I have HONDA CIVIC DX 1994 SEDAN 4 DOORS.
Type of engine D15B7
and when I got to 1500RPM in the gauge its start to jump (if I put more gas the jumping is gone).
I asked people in my country and they told me I need to clean the IACV.
Is this the only part that can make this problem?
The simple solution is to clean it?
Do I need special material to clean it? (carb spray is very strong and I am afraid of the sensors)
Appreciate your help and knowledge specially people who have this specific problem and resolve it.
Thank you
Old 03-31-2016, 06:34 AM
mk378's Avatar
Default Re: RPM JUMP AT 1500
If you ignore the gauge, does the car drive smoothly?
Old 03-31-2016, 06:39 AM
Asaf's Avatar
Post Re: RPM JUMP AT 1500
No when I am in 1500RPM it feels like the car is bouncing.
Also if its help you to get more information when I stand in red light for example the rpm is very low like 300 and the car is really shaking.
Thank you
Old 03-31-2016, 10:20 AM
Former User's Avatar
Sounds like a misfire issue. Post the CEL codes, and do an ignition system tune up if the parts are old. Then go from there.
Old 03-31-2016, 10:22 AM
nnac7270's Avatar
First you should check if you have a cel then go from there. If not clean the IACV and its also a good idea to clean the throttle body. You can use carb cleaner or just use throttle body cleaner they are both similar. Also a good idea to check and make sure your air filter isn't clogged.
Old 03-31-2016, 10:32 AM
Asaf's Avatar
Carb cleaner 100% don't damage the IACV at all?
Thank you
Old 03-31-2016, 10:54 AM
nnac7270's Avatar
Thank you
I've used it and many other people have just spray it where needed and not the electrical components. Check this tutorial here https://honda-tech.com/acura-integra...valve-1575913/
Old 03-31-2016, 11:41 AM
Asaf's Avatar
Thank you will check.
Old 03-31-2016, 01:00 PM
White_EG1's Avatar
You actually disconnect the IACV from the sensor and coolant line then clean it.
I fill the bucket with carb cleaner then soak it.
Make sure to remove the gasket before soaking.
Old 03-31-2016, 01:29 PM
Asaf's Avatar
You had this problem before?
After cleaning the IACV you press gas until 1500rpm and it was stable without jumping?
Thank you
Old 03-31-2016, 01:31 PM
^Does not fit with idle problem.
Old 03-31-2016, 03:45 PM
Asaf's Avatar
This is my problem I have added a video to give you the best real time situation.
So please if someone has\was this exact problem and resolve it I will appreciate the help.
Thank you
File Type: mov
Old 03-31-2016, 03:49 PM
With the engine warmed up, what happens if you don't touch the gas pedal and just let the engine idle?
Old 04-01-2016, 05:48 AM
Asaf's Avatar
The RPM gauge stand steady not moving a bit.
Thank you
Old 04-01-2016, 07:19 AM
You don't have an idle problem.
Old 03-27-2019, 12:51 AM
Claydooo's Avatar
Has anyone been able to solve this?
DJArvidsson
03-17-2013 02:02 PM
christopherLom
13
09-29-2011 10:53 AM
BlitzSix
05-30-2011 09:20 AM
abadkevin
04-25-2010 02:21 AM
Quick Reply: RPM JUMP AT 1500
