Rings for D15B same as D16?
Old 12-03-2004, 11:06 AM
Blanket Jackson's Avatar
Default Rings for D15B same as D16?
I am in search of a set of piston rings for a D15B. The kicker, I cannot get JDM parts from Honda through my work. I was told by a couple people that D16 piston rings might work, but I was also told that the piston ring thickness was thinner on the JDM motor. Am I going to need D15B piston rings or can I use a certain D16 motor for it's piston rings?
I am sorry if I cannot post this question here. MODS, if you wanna move it. Go ahead, but I need to find a solution to my problem.
Cliffs-I NEED TO FIND RINGS FOR A D15B
Old 12-03-2004, 11:37 AM
usdmike's Avatar
Default Re: Rings for D15B same as D16? (HONDAofPOKY)
hope this helps
https://honda-tech.com/zerothread?id=883991
Quote, originally posted by HumanResource »
how is that wrong???
D16Z6 rings should be right
No, the Z6 rings are wrong. My D15B has the DX PM3 pistons and required the thinner DX rings. The Z6 rings are too thick to fit in the ringlands.
Old 12-03-2004, 12:00 PM
Sorry for not Archiving my search, but I am little behind on time. I work for HONDA and I need these rings asap. Where can I find stock sized rings?
Old 12-03-2004, 12:51 PM
Jim Truett's Avatar
Default Re: (HONDAofPOKY)
Somehow I misworded my statement above.
It should read:
D15B7 PM3 piston rings fit the P08 Pistons. The rings are thinner than the 1.6l units.
Old 12-04-2004, 07:20 AM
Aight
ziurek filmus
04-16-2017 10:17 PM
boostontheD
05-06-2008 06:37 AM
All jdm
06-04-2004 08:22 PM
Quick Reply: Rings for D15B same as D16?
