Ring gear clamp! READ!
Does anyone know where i can get a ring gear clamp for the flywheel on my JDM D15b??? that motha moves around to much to bream the bolts loose, i went to my local parts places and they were like LMK please!!
Re: Ring gear clamp! READ! (nfinitecc)
I'm a little confused. Are you trying to remove the flywheel bolts? I got them out by jamming a screwdirver between the teeth and whacking the wrench/socket with a hammer.
Re: Ring gear clamp! READ! (t0p_sh0tta)
i am trying to get the flywheel bolts off yes, i figured this tool would also make it easier to install on my new motor, if its moving around alot i won't be able to get accurate torque specs, i thought about a screwdriver but don't want to damage the flywheel....
Re: Ring gear clamp! READ! (Dan GSR)
Breaker bar or 1/2 inch with a nice cheater bar on the crank pully and place it on the floor, and go to work with the flywheel bolts.
Re: Ring gear clamp! READ! (Luserkid)
DAMN!!!!! 95$ for that little piece of shiat!! o well a member of H-i.com just enlightened me on the crank pulley bolt.... why the hell didn't i think of that???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Having the right tool makes the job MUCH easier.</TD></TR></TABLE>
I've been in situations, where I was struggling for a long time trying to do something
and then I say **** it, and just buy the proper tool, and it takes 2 seconds to finish
use an impact wrench barely tries to move. i have also used a screwdriver wedged between frame and flywheel. You could make the tool in ten minutes with a mill or maybe 20 minutes with hand tools just measure and cut or weld something to a slotted washer and your good to go.
Juan_Mitosis
60
05-20-2016 07:20 AM
JDMInspired
Honda Civic (2001 - 2005)
03-17-2008 08:57 AM
