revving high at idle quick help. cel checked!
Hey everyone my 96 gsr in a 98ek threw an o2 sensor and tps code. I cleaned the iacv and blew air through the fitv since its welded on there some how lol (bolt underneath impossible to get at) pretty sure.
anyway does anyone see those causing the idle issue? right now is a stock p72 but im converting it to obd1 and running a basemap with the o2 disabled but normally thats just the secondary. does a jdm gsr search for one or two o2 sensors?
Re: revving high at idle quick help. cel checked!
i couldnt check before so i cleaned it anyway before hand.
Now, will any tps work or am I fkd and need a GSR tps? b18 work?
lol sry for being useless
I tested it it touched .5v for a second but could only hold steady at .47ish.
problem? yes I think so. So I will pull a couple off some scrap cars. they are interchangeable 88-01
now im throwing a code for o2. motor is jdm. car is usdm. that would be the secondary o2 the car is searching for? bc I will disable it in chrome and take my chances with the smog test as the primary probably works. car pulls ok I think
so simple
10-16-2009 01:43 PM
