reseting the ECU?
reseting the ECU?
How do you reset a ECU in a 95 civic?...I heard you can gain 5+hp after doing so...is this true? and is it a good Idea?..if so, does anyone know how?..please help..thank you
Re: reseting the ECU? (JDM_lover03)
well you can pull the ecu fuse for like 5 minutes or just unplug the negative terminal on the battery. As for gaining 5 hp....not likely. But resetting the ecu should be common practice after performing any performance mod to your car.
