researching higher compression
you guys know any type of website that would give me massive amounts of information on building a higher compression motor? or where i can get a hold of some material that would make me more knowledgable on the aspect of building a high comp. motor. i wanna build my d16y8. please leave out swap alternatives and such.......i wanna go n/a with my SOHC. thanks....
Re: researching higher compression (SO[vtec]HC)
http://hybrid.honda-perf.org/ would be a good place to start. Granted, most of the info on there is about swaps and how-to's and stuff, but there is some info about high compression (you just have to look for it). JG Luder (moderator of prelude forum) knows just about everything there is to know about high compression on an H22A. A lot of the concepts are very similar, you might ask him where to find info).
Well I don't know of any sites...
I don't want to have to say this, but for the price it'd cost of making your SOHC come close to making the power of a B16a(One of the cheaper swaps) it would be a lot more reliable and would run better if you just got the B16a. Might have problems smogging after fixing up the SOHC(If you get real serious), and might even be cheaper for a swap.
But you're looking at getting some forged pistons, rods, new rings, bearings, springs, retainers, valves, get your rev limit raised and all the bolt ons. I don't know if they make a Cam for the SOHC, could probably get it reground. Maybe even get a thinner head gasket to raise compression. Mill the head. There's lots of stuff you can do. I would say N2O, but you're N/A. Well, goodluck!
Re: researching higher compression (OR-G)
Yes, someone does make an actual billet cam for the SOHC. Something's bugging me saying that it is Crower that makes the cam, but I'm not sure. Someone please confirm this for me. Whoever it is, everyone else's cams are reground and not as good.
You can put N2O on a N/A engine, you just have to be REALLY CAREFUL tuning and using it.
i dont want to have crazy power. its a simple street car. i just need that edge if someone wants to pull a fast one.
Re: researching higher compression (spyder)
First of all OR-G, I'm not flaming you. I'm just pointing out that he knows about the cost and has already decided to stay with the SOHC. There is no longer any point in even mentioning swaps.
To be honest, if that's what you want, then you don't want high compression. A good number of completely stock domestic SEDANS will hand even a high-compression SOHC its *** on a silver platter. What you want is a small to mid-size turbo. You still have the opportunity to build the internals with a turbo. It lets you have the best of both worlds. You can have decent performance or absolutely insane performance at the flick of a switch.
Yeah, I can understand not wanting a swap, everybody and their freakin dog has one. Keep in mind that you can get decent power putting a turbo on the SOHC, you don't have to swap for that. Just a thought, will be glad to help in whatever path you follow.
Well Spyder I was just suggesting, as I did not know exactly what he is intending. Some people believe they can stick with the SOHC make the same power as a DOHC and have it be cheaper and run better since it's the original motor. I was just pointing out the swap is usually better in all aspecs.
Since he knows what he wants to do, and as long as he does his research then more power to him
and we ran it that night
You crank it up and see how it runs, then you cruise at 10mph for a while, then 20, then 30 and so on until you are up to freeway speeds. you don't punch the throttle at all until you are up at 300-500 miles since the installation. This gives the parts a chance to break in and you a chance to see if anything is wrong before you really start stressing things out.
If done correctly, there is nothing to fear about a turbo.
That's exactly why it blew. When you put a turbo on a car, you are supposed to break it in gradually just as if the car were brand new.
98civicEX
07-31-2002 07:16 PM
