Replacing Front Turn Signal Bulb
Old 10-26-2005, 05:17 PM
lilredracer's Avatar
Default Replacing Front Turn Signal Bulb
I haven't had to replace a turn signal bulb on my car yet...well, the time has finally come that it went out.
How do I replace the bulb? I have taken all the bolts out that I can find and the headlight itself still seems to be caught on something, or is there another bolt that I am not taking out?
The bulb that is out is my Left front turn signal.
Can anyone help with the easiest way to replace?
Thanks so Much!
Old 10-26-2005, 05:36 PM
Stoich EG2's Avatar
Default Re: Replacing Front Turn Signal Bulb (Senses Fail y0!)
WHAT KIND OF CAR IS THIS?
Old 10-26-2005, 05:40 PM
kingSfit's Avatar
if this is for an 92-95 civic simply
pop your hood, look at the corner light there should be a phillips screw above it (you cant miss it) unscrew that and you would be able to slide out the corner light, onces its out of place look behind it ** just turn it clockwise or counter and it will pop out ***note*** when putting in the new bulb, it will work both ways , so try out both ways and see which gives a better lighting
Old 10-26-2005, 06:41 PM
Default Re: Replacing Front Turn Signal Bulb (ADVAN EG2)
1997 civic
Old 10-26-2005, 06:42 PM
Default Re: (bbun)
I appreciate the post! I had a blonde moment and forgot one thing - my car is a 1997 civic! Thank so much though!
MDAMP2005
10-31-2018 06:51 AM
slamstrom
04-12-2017 04:50 AM
Acethriller
Lighting
01-04-2014 07:58 PM
Alibi86
08-11-2005 09:39 PM
Boost2NA
11-17-2002 12:11 PM
Quick Reply: Replacing Front Turn Signal Bulb
