Removing Upper Timing Belt Shield
I have a 93 CX. . and I want to check the status of my timing belt. Do I have to completely remove the head to take off the upper half of the timing belt shield? Last night, I undid the two screws at the bottom of the upper half. . .and I wasn't able to remove the cover.
Re: Removing Upper Timing Belt Shield (93SSPHatch)
you have to take the valve cover off to get that upper timing belt cover off there. Don't have to take off the whole head though...
just make sure when you put the valve cover back on that you don't break any of the bolts (unless you want to be an idiot like me )
Re: Removing Upper Timing Belt Shield (matt-eg)
Is there any special way to remove the valve cover? What tool(s) am I going to need? Does the engine need to be cool?
Unplug the negative battery terminal. Then off the spark plug caps. Make sure you mark them first so you know which goes into which sparkplug. Disconnect your vacum line. Undo the ground wire. Unscrew all the screws around the valve cover( should be 8). Make sure you don't drop any nuts into the spark plug chambers. Remove the rubber washers and carefully lift the valve cover. Thats it . Oh yeah - the engine should be cool. All you need is a 10mm socket.(I think)
[Modified by whatcivic, 6:23 AM 5/30/2002]
Re: Removing Upper Timing Belt Shield (whatcivic)
I am a complete newbie to engine repair and maintenance. . .where is the vacuum line located? Sorry for the stupid question. . .but I don't want to screw anything up!
Thanks for putting up with the stupid q's!
It's the rubber hose coming from your intake piping to the valve cover - the only hose connected to the valve cover. When putting on your valve cover you might want to change the valve cover gasket and make sure you silicone all the bends(corners).
[Modified by whatcivic, 6:29 AM 5/30/2002]
Thank you! Hopefully this will go smoothly. . .I am going to attempt the removal tomorrow.
[Modified by 93SSPHatch, 10:29 PM 5/29/2002]
once you have the timing belt cover off, use a dremel to cut away the piece that goes under the valve cover... not too much, just enough so its flush. it will save you time in the future
Re: Removing Upper Timing Belt Shield (Zer0DazE)
If your planning to take all of this off to check, just go ahead and replace the belt. It's like $20 from Honda, and they look pretty good until they skip a tooth. My uncle's accord (86) jumped the timing belt and everything looked great except for the one tooth that was ripped off. Better to be safe than sorry!
Re: Removing Upper Timing Belt Shield (Ricey McRicerton)
I'm pretty sure I don't have the mechanic knowledge to change my timing belt. . .i wish i did, I would save me about $500!
I was reading in my Hayne's manual that I should place RTV sealant in the corners of the valve cover whenever I take it off and put it back on. Is this necessary. . .or is it just a good idea?
is it that hard to change out the timing belt b/c i think i'm about due for a new belt... oh btw i have a haynes book should that make the process easier?
I was looking today. . and I noticed that there was dried oil all around the front of the valve cover. . .this probably means new valve cover gasket. I went to try and remove the cover today. . .but I could pull it off. . .everything was unscrewed and unattached. The engine was still warm. . does this have anything to do with it?
SteveT2008
07-17-2015 08:25 PM
rice h8r
07-15-2011 09:32 PM
idriveadelsol7
12-18-2005 12:23 PM
