DAmn Hot out GSr ac lines Fit in eg???
Old 06-30-2003, 09:50 PM
BanUglyImportModel's Avatar
Default DAmn Hot out GSr ac lines Fit in eg???
I have a integra ac comppressr working with my 95 civic's entire a/c system( condeser, etc etc.) Does anyone know if gsr ac lines from the compressor to the condenser will fit better with my existing setup? as u can see on the pic the oem civic ac lines had to be bent and twisted to fit.
Old 06-30-2003, 10:42 PM
Pho Real's Avatar
Default Re: DAmn Hot out GSr ac lines Fit in eg??? (BanUglyImportModel)
I had custom lines made, I think you are supposed to use a Del Sol Dohc VTEC A/C bracket or some **** and then your stock lines will work. But maybe that is for a stock civic compressor. Any Confirm This?
Old 06-30-2003, 10:51 PM
Default Re: DAmn Hot out GSr ac lines Fit in eg??? (Pho Real)
yea stock civic compressor with del sol bracket works, ididnt know at 1st and bought a gsr compressor and sold the civic one so im stuck with the gsr. How much did u pay for the custom lines? Thanks
Old 06-30-2003, 10:55 PM
SpoonFedHatch's Avatar
just keep the compressor and do this....
i did it about 3 months ago and it holds FINE WITH NO LEAKAGE.....just use hose clamps to tighten the hoses to the coupler (can be found at HomeDepot) and it'll fit FINE.....
all you have to do is pick up the teg's high side hose from a junkyard for like $10 and you're set
PS.....make sure your system is evacuated so there is no pressure in your system when you take off the lines, and use new o-rings too
Old 07-01-2003, 04:02 AM
Sivicfied's Avatar
Default Re: DAmn Hot out GSr ac lines Fit in eg??? (SpoonFedHatch)
What about the evaporator (the can between the PS and washer)? My power line from the harness to the evap doesn't seem long enough or I could be routing it inefficiently (GSR AC system in EG w/ B16A) is this normal? Anybody have pix of the evap and its original location in an EG with proper routing of the power connector? Sorry to hijack the thread.
Old 07-01-2003, 04:59 AM
jolt-tsp's Avatar
Wow, love that artwork. It is actually really helpful
Old 07-01-2003, 09:08 AM
Default Re: DAmn Hot out GSr ac lines Fit in eg??? (Sivicfied)
I have a civic system so everything else fits perfectly except the compressor and lines. Im not sure of how the power harness is routed to the evaporator try to go to like the magestic honda parts website and look at the harness u talking about and how it routes on the diagrams.
NIce pics of the cut and paste.
Old 07-01-2003, 11:58 AM
Pho Real's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BanUglyImportModel &raquo;</TD></TR><TR><TD CLASS="quote">yea stock civic compressor with del sol bracket works, ididnt know at 1st and bought a gsr compressor and sold the civic one so im stuck with the gsr. How much did u pay for the custom lines? Thanks
$75 Installed
Old 07-03-2003, 07:42 AM
Sivicfied's Avatar
[QUOTE=BanUglyImportModel]I have a civic system so everything else fits perfectly except the compressor and lines. Im not sure of how the power harness is routed to the evaporator try to go to like the magestic honda parts website and look at the harness u talking about and how it routes on the diagrams.[QUOTE]
I checked it out but didn't see what I was looking for. Do you have pix of your engine bay where the receiver is located or basically the drivers side. Thanks in advance.
Domani99
09-01-2011 06:40 PM
delsoleg2
03-16-2011 01:46 AM
lPat
08-21-2007 03:14 PM
rezneffix
05-16-2007 09:54 PM
marc-111
08-24-2005 12:47 PM
Quick Reply: DAmn Hot out GSr ac lines Fit in eg???
