removing door panels... searched but still need help
Ok after reading some threads abouth ow to remove the door panel... i got all the screws off.. the door panel is off the clips but i cant seem to get the whole thing off? do i need to take the window handle out or something? its a 94 ex manual windows.. thanks
Re: removing door panels... searched but still need help (vlc92189)
to take of door panels on an ex with power windows all you have to do is take of the screw near the the front edge of the window and the screw for the door handle and the screw for the power window switch, as for the manual i think it should be somewhat the same except for the manual window you would just keep turning it til it stops and then i think it pops of when you pull it away from the door. I had to do that before for a talon door panel with manual windows. the window handle isn't screwed in it just pops of in order to take of the door panel.
if by window handle you mean the window crank. yes that has to come off. on the backside its like a u-shaped clip. get a flat head a pry one side up and it'll pop off. dont loose it. they're hard to find and like 3 bucks for a dealer. that clip keeps your crank on. pull the handle of the crank off and the door panel will come right off, as long as you got all the screws including the ones in the little cup that u grab to close the door and the actual handle. good luck
davidbui
12
01-08-2002 07:32 AM
