Refresh of 94 Civic Si w/ ABS after accident
#451
Re: Refresh of 94 Civic Si w/ ABS after accident
Thanks! I am going to pick some up for the rear LCA project, and for the brake slide pins.
I decided to get brake pads as well and will do those while I am in there. I have not done the rear pads in years, and I do not like the fronts. I saw in a different thread that the OEM pads are Nissin, which were the last set of front pads that I liked...
#453
Premium Member
Alright, I can feel my ADD kicking in here a little bit, so I think I need to make a list of things I want to do to make the Si a little more DD friendly:
Just noticed my list references squirters and tranny...
- New muffler - WS2 80mm Turbo Universal - looks like it will fit, but before I do that, I want to install #2 (below)
- Rear swaybar - EX or DC2 Integra - requires tapped LCAs, might as well do #3 while I am in there,
- LCA & RTA bushings
- WIndsheild squirters - Fit - 76810-S10-A01,
Tranny lube - GM Synchromesh FM MTF + Moly Slip- IAB - get it working - why doesn't it work???
- Front brake pads - Nissin semi-metal
- Front end sheet metal + bumper skin
- Depo light housings
I got a chance to take a look at my RTA bushings - they look torn up! I can't wait for the new ones to show up. I still have not seen shipping confirmation from Honda. I wonder if they are having trouble getting those LCAs in?
#454
I got to cross one item off the list - got the GM FM SynchroMesh MTF in that B-series transmixer. So far it feels marginally better. I think it was @TomCat39 who said it takes a few miles before that stuff works its magic. We will see.
From the Honda MTF, it would likely only be a small difference. But for my understanding the GM Synchro FM is closer in formulation to the old MTF that was made for the 5th and 6th gen manuals. Current Honda MTF has been reformulated for the current manuals but is still "okay" for the older ones.
Really, the best of the best is still probably Torco, but it also has a much shorter change interval so adds up after awhile.
#455
Premium Member
I never said any distance or time. For me I noticed immediately the difference when I did the GM Synchro FM and Molyslip. But I had also downgraded from Honda MTF to Pennzoil Synchromesh (not FM) and was not liking it at all.
#458
I also do another additive, but most people will say it's snake oil. I however feel it keeps and can even bring back some use in a worn but not broke manual transmission.
I have had zero issues and great success when I keep Xado Manual Transmission EX120 in the gear box. It seems to keep the dreaded ISB problem away no matter how much I abused the high mileage transmission I've had.
Been doing it for years now with no ill effects and the bearings have always stayed in great condition.
I know most people will say snake oil, but I've had some interesting results with it, including getting rid of a mild knock in my old engine. After 4 or 5 treatments the knock was finally going away and then I got stupid and did the WOT stone cold engine burn out cuz I was pissed at kids and got the knock right back after months and months of work to get rid of it. Then I swapped the engine.
Anyways, I believe in the stuff to keep things going as they are with my abuse and so far it's worked. And it's never harmed anything to date. Only used the engine and the manual tranny additives though.
#459
Premium Member
Not a corner, just literally creeping up to a light and trying to time my approach so I can roll, but the light is messing with me and making me stop. Way too slow for 2nd, unless you want to lug the engine, which I hate...
#460
Premium Member
https://www.amazon.com/XADO-Revitali...l+transmission
#461
Input Shaft Bearing (ISB) is a known bearing to wear first and start causing chatter.
If you don't replace it (requires cracking the case open) when it starts to chatter it can destroy the transmission when it finally fails. It tends to be the bearing that takes the most force and so is the first to show wear symptoms in most cases.
#462
Corvette Forum Member
My Sedan had that issue when I first bought it. Honestly not too bad of a job once you've done it once or twice. Just be careful with the snap ring! I detailed it rather closely in my refresh thread.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-ex-sedan-refresh-series-unfortunate-events-3290093/
#463
P20/A000 Repair (ISB replacement)
Of note at the end of my thread (when I was learning the differences between USDM and CDM gear ratios) I was going to go with synthetic motor oil for the tranny. I learned going synthetic is not recommended. Stick with conventional dyno oil if you want to do the 10w30 motor oil method.
Also I learned, the Pennzoil Synchromesh sucked badly, especially in cold weather. Definitely need GM FM with molyslip, that seems to be the best method outside of Torco MTF.
#465
That's exactly what I did, the one drawback is the air condenses quite a bit of water in the bearing. I flushed mine out with the molyslip additive as best as possible before assembly after I got the bearing into that half of the case. I didn't like the idea of that much water initiating the brand new bearing before the oil got up there. Let alone having that much water in the case to contaminate the oil to start with.
#466
Fish Twig
#467
#1 Super Guy
Could you simply freeze it in a cup of 0w20 (or your preferred MTF), then simply take the cup with you, remove the bearing, and drop in? Wouldn't have time to collect condensation and cold oil would still repel water correct?
#468
Premium Member
The other thought that occurred to me is that I am running a short-throw shifter, so that must require more effort if I have a shorter lever...
#469
Premium Member
I too detailed when I did mine in my Condo on the Dining Room floor, including a flashlight poor man seal driver LoL:
#472
That's actually not a bad idea. The air is still going to condense on the oil but at least there is the barrier.
Really though, I wouldn't worry about it and instead of trying to flush it with oil, I'd shoot it with brake cleaner. Since it's alcohol based it absorbs the water and evaporates/displaces very efficiently.
I was in a hurry and sitting in my dining room so wanted to avoid a well ventilation required product.
#473
Premium Member
Great ideas. Has me thinking about the -80 degrees C freezers we have here at work... That and leaving the case out in the sun should do the trick!
#474
Sounds like overkill. Just tossing it in our freezer at home (not deep freezer just fridge freezer) for 4 hours before I went to do it let me pop it in without any issue. I don't even think I had to tap it much.
#475
Premium Member
I kinda assumed they were different manufactures of parts for cars built in different countries. They at least will be interchangeable/compatible if you insist on sticking with OEM. Originally there was also be different shock/spring setups for the various vehicles.
I can definitely say that just because it "appears" in available to purchase, doesn't mean it actually is. The parts for these cars are disappearing daily. If you are really interested in purchasing OEM, I highly recommend you contact your parts person right away to confirm availability of anything you want. In the last few months of parts searching, I would say less than 50% of the parts I requested for the 5th gen Civic were still available between Canada and USA. Almost all the interior stuff is already gone. Lots of the exterior stuff is getting harder to find too and the prices are already jacking up.
Now that I look at the pictures, I think I labeled the bags incorrectly:
