Redneck 101 rebuild update.........
D Tranny Guru
https://honda-tech.com/zerothread?id=262374
15.09 @ 90 mph on puny 175/50/13's!
2.3x 60 foot.
Had all my slicks loaned out so I had to run street tires.
Next step is slicks and hope for a 14.7x, then bigger injectors and go for 12's on the juice.
And it will!!!!
2.3x 60 foot.
And it will!!!!
Re: Redneck 101 rebuild update......... (Hallusin8.com)
Mista, what does your car weigh in at? Still using the "no-back bumper" trick @ the track?
I'm about to go no bumpers at the track
Re: Redneck 101 rebuild update......... (Mrfirefox)
I beileve that he ran this on a "hurt" z6 block (i think the #3 cyl is leaking a wee bit). With y8 pistons and rods just thrown in. I,H,E, fuel tuning i guess, and a good driver ... Am i right bone..
DId the y8 pistons and rods up the compression ratio or something? that is hella fast for them skinnys
Jeremy .....all about the SOHC "Power"
D Tranny Guru
Re: Redneck 101 rebuild update......... (JSutterEH2)
correct Jeremy...........
The compression ratio MAY have went up .1, but that would be about it.
No changes in the tuning, just what I always had it set at.
45 psi and 19 BTDC.
I guess car weight was about 2050-2100 + driver. I did leave the passenger seat in this time.
Also, I don't own a rear bumper cover. It blew out of my pickup a few years ago (long story) and a 18 wheeler found it before me. The only downside is now the bumper bar is about rusted in 2, although you can't see it.
45 psi and 19 BTDC.
Re: Redneck 101 rebuild update......... (Mista Bone)
you gotta love the sohc power...everybody says swap to this, swap to that...why when you can have so much more fun (and save a hell of a lot of money) playing with a sohc engine...now that is some honda fun...
james
james
D Tranny Guru
Re: Redneck 101 rebuild update......... (ihaterice)
saw 3 5g HB's with swaps, best they could muster was 14.8x.........
Not bad for $5000 an a non driver.
SOHC will owned you, someday.
I like being the underdog. You get no attention till you WAX *** on the big dogs.
question... how much DO those wee tires effect gearing. I see you cut a 2.3 which is totally rad considering the 5 inches of tread(what PSI were they)
Jeremy
Jeremy
sounds nice...since i cannot run slicks at the local track on street night i might invest in some suimtumo* 175/50/13 for the steal wheels.. Could help quite a bit bc i seem to lose a lot of power in 3rd and 4th with the sock. Thanks
