Recognizing Lean Burn in '97 HX w/5-spd?
'97 Civic HX w/5-spd.
How do I keep it in lean burn the maximum amount of time?
What conditions make it go into/out of lean burn?
Someone said that non-US versions had an indicator for lean burn but I haven't found how to hook up to that circuit.
Comments?
Comments?
Re: Recognizing Lean Burn in '97 HX w/5-spd?
you can also get an aftermarket air/fuel gauge and wire it in, I'm not sure which wire it is but you can tap into it directly at the ecu.
