rear lower control arm, JDM & USDM?
Re: rear lower control arm, JDM & USDM? (intezn)
Your talking about the rear lca right?
on the ek chassis they are the same.
on the eg chassis they are different. JDM lca's are the same as those found on the itr.
The same goes for ef's. They have the '88 style lca wich is the same as the itr lca's.
The only differences in the jdm eg&ef lca's from the itr's. Is that some of them do not have a welded in nut for mounting the swaybar. However the hole is still there and you can just use a lock nut.
mugenracer
03-17-2003 06:52 PM
