rear disc brake questions
I have a 99 civic coupe I swaped the rear trailing arms for disc, the guy I bought it from said it was from a JDM civic. The brakes are now starting to go, if they are JDM is there even a difference between integra or civic si discs and pads, also i noticed after i bought them that one of the trailing arms was for a car equiped with ABS, should this change the parts I wouls need? pads and discs look the same, Thanks in advance
Re: rear disc brake questions
No, the fact that they were ABS brakes does not change any parts, they will use the same pads as non-ABS equipped rear disc brakes. Not sure about the difference from JDM Civic brake pads but I believe they might be like GSR (Integra pads) but someone correct me if I am wrong.
luispizarro25
06-17-2009 03:25 PM
