rear dic converstion
Re: rear dic converstion (delslowly93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslowly93 »</TD></TR><TR><TD CLASS="quote">improved braking with larger master cylinder </TD></TR></TABLE>
That's wrong from what I've heard. Braking isn't improved, the FEELING in the pedal is improved.
Re: rear dic converstion (mrlegoman)
i track my car with my disc conversion, using the stock CX brake booster and prop valve. Brakes feel fine. No problems. Mind it is just AutoX and not HPDE, not yet atleast
be professional
Re: rear dic converstion (mycivic93dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivic93dx »</TD></TR><TR><TD CLASS="quote">do i have to change the master cylinder and the brake booster from dx to ex or can i use the same one. can anyone help me out.</TD></TR></TABLE>
Just use the existing one. There is no need to upsize the master cylinder when doing a rear disc conversion, unless you are also converting to larger calipers up front. Honda didn't find it necessary to do (see EH3 non-ABS for example), and I don't either.
Wrong. The master cylinder size has no effect whatsoever on braking performance - only pedal feel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman »</TD></TR><TR><TD CLASS="quote">You fine for daily driving, but I would be skeptical if you track it.</TD></TR></TABLE>
It makes no difference what the car is being used for.
Re: rear dic converstion (Targa250R)
for rear only, fine I'm sure. I'm in the middle of front and rear, and I'm swapping to gsr 1" master, and brake booster with 4040 valve. Should be nice.
eskerley
01-23-2008 03:24 PM
HYBRIDJDM WAGON
10-17-2003 10:11 AM
