Rear defrost won't work. any ideas?
Re: Rear defrost won't work. any ideas? (Unjockable)
maybe yours is like mine. my rear defroster doesnt work because the owner before me tinted the window, or so he said. how do i get them to work? i drive a sol by the way, so if anybody knows, help out.
check under your hood in the box
look at the relay for the defroster
if that dont work
check out your connections and ground
if thats not the problem i dunno haha
if that dont work
Pooping on children
Re: Rear defrost won't work. any ideas? (jL iLLuZiOnz 9)
the reason they dont work is beacause he took the tint of probaly with a razorblade and took the bars with it<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">maybe yours is like mine. my rear defroster doesnt work because the owner before me tinted the window, or so he said. how do i get them to work? i drive a sol by the way, so if anybody knows, help out.</TD></TR></TABLE>
Re: Rear defrost won't work. any ideas? (BADEG6)
well if it all looks like it should work check your connections..do you have a light for your defroster? i do in my EK...check connections.
look at the back window on either side, you should see a spade connection with wire connected to the vertical bars at the edge of the glass.
If those are connected, then you can do a resistance check between the two vertical bars by removing the connectors to the glass, and use multimeter (set to the ohm position) to ensure that there is at least one path for electrons to flow. If you don't have a meter, you can do a visual check of the horizontal bars checking for cuts or scrapes.
Meters are cheap (10 bucks) at Radio Shack, you don't need a fancy one
Re: (KayOs)
Can you take a pic?
If it can be soldered, maybe, but it dependes on how it broke off. You can't just glue it because it has to conduct electricity.
If you can't get a pic, go to a auto glass shop.
ravenwoodranch
11-20-2012 06:50 PM
