Raxels?
Raxels?
Anyone ever heard of or used Raxels axels? I am being fucked by my axels trying to do a JDM ITR 5 lug conversion on my car which has a D series engine. None of the splines are the same and its just not working. I'm probably going to have to order custom axels from Raxels.
Re: Raxels? (Ninety2SiR)
Did you get the new parts from a Japanese market car? I'm under the impression they use beefier axles and have a larger diameter hub bearing. I hope you intend on upgrading to a B-series engine, because a 5 lug conversion seems really silly if you're not.
I have heard great things about raxles, but i have snapped a raxles stage 1 before... i was N/A with boltons, and it sheared the splines right off... Defective material... The guys at JUN and I took it apart at e-town, and were like "****... cant fix this axle".... so i went back to OEM's... I might consider raxles again though...
Re: Raxels? (Mike P.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike P. »</TD></TR><TR><TD CLASS="quote">Did you get the new parts from a Japanese market car? I'm under the impression they use beefier axles and have a larger diameter hub bearing. I hope you intend on upgrading to a B-series engine, because a 5 lug conversion seems really silly if you're not.</TD></TR></TABLE>
I actually have my swap sitting in my garage. Its not going in for a while, I have a massive build up planned.
The DSS stage 3 axels are pretty good, I helped install them in a B16A CRX. I just bought a set of stage 2 Gator axels that look very good to use in my Civic.
The Gators cost alot less than the stage 3 DSS plus they use my Civic hubs and should hold similar power. I'd give them a good look also. Contact Stan (Flamenco-T) he will take good care of you
I 'm pretty sure Gator or DSS can custom build axels to match your alternate hub spline/trans spline combination.
.jacob
25
05-13-2004 08:40 PM
